autoloc on 5spd g3 integ
Old 04-04-2003 | 10:38 AM
Level_7's Avatar
Level_7
agreed. it's easy to shift without using the clutch. i place mine over the brake pedal.
Now the car is even easier to steal...at least when it's on the clutch the thief has to bypass the clutch depressed relay to the starter...now he can just step on the clutch and start the car. He doesn't need the brake anyway...if he stays under 40km/h, the hand brake works just fine. I would say the gas is the better place then.
Old 04-04-2003 | 11:05 AM
reno96teg's Avatar
easier? in your opinion, maybe.
i don't know about you, but i'd rather have to force gears than have no brakes. i doubt he'd get very far with only the e-brake.
Old 04-04-2003 | 11:28 AM
BlackAckeR's Avatar
BlackAckeR
Default Re: autoloc on 5spd g3 integ
Originally posted by GSRacer93
does anyone have a 3rd gen with the autoloc? i was curious how you people would use it because the only solution i have found to put it on is by taking out the foot rest. i kinda miss it, it took me a while to get used to it. i wanted to know what all u other people have come up with if u have the autoloc. i want to put the foot rest back in...i got a spare one so i can cut it up.
I think you are putting it on upside down (seriously!)...
The lock should be facing the right side, and it fits fine with the footrest in place.
Old 04-04-2003 | 01:57 PM
GSRacer93's Avatar
GSRacer93
He's so hot rite now
mine must be a different autolock because the lock faces you...not to either side. i think it's a newer one. i have seen the ones with the lock that faces to the side, and i have tried to put mine in upside down...but the lock just gets in the way. mine is the autolock pro....if that helps any....
