Experiences with integra gs/rs/se auto tranny
Could anyone share their experiences with the ****ty auto tranny of the integra se?
How well does it ride and shift and problem areas you have noticed.
I have
1995 integra se auto
koni yellows
eibach sportline
potenza s03's
4-2-1 header
2.25" exhaust
ngk plugs/wires
aem cold air intake
And what I can share is that my tranny seems to hold well at WOT but at low speeds it is very jerky at low speeds but fine depending on how you're handling the gas pedal. It seems very slow to react.
Has anyone who put in a turbo noticed a reduction of jerking or is my tranny just dying?
I have
koni yellows
eibach sportline
potenza s03's
4-2-1 header
2.25" exhaust
ngk plugs/wires
aem cold air intake
Originally posted by Taiwanze7
the tranny isn't made to handle power, *going through my second one* and its still having problems
Originally posted by chicagovelocity
I have the same ride you do...
Do you shift at all? or do you just keep it in D3/D4?
Has anyone changed their crank shaft pulley with a lighter URacing and has it made a big difference on torque/throttle response or would I just be wasting my money? I'm also wondering if a digital ignition with a high voltage coil help the weak powerband in the low rpms with the integra automatic.
Originally posted by WiLL
what happened to the first? also what mods do you have?
Re: Experiences with integra gs/rs/se auto tranny
I have
koni yellows
eibach sportline
potenza s03's
4-2-1 header
2.25" exhaust
ngk plugs/wires
aem cold air intake
I have
koni yellows
eibach sportline
potenza s03's
4-2-1 header
2.25" exhaust
ngk plugs/wires
aem cold air intake
yo, i'm thinking of putting same mods as you-I/H/E on my auto- did you feel a significant increase or not really?
Re: Re: Experiences with integra gs/rs/se auto tranny
As far as the combo of those three mods, providing you got 2.25 in exhaust the whole way, I would say they add about 20-30 whp to the car.
I had a B&M fuel pressure modifier which I found was useful for upping my fuel pressure to 39 psi which compensated for some defiencies in air/fuel with the i/h/e mods... its about 65$ or something.
My suggestion for auto owners:
get the cold air intake, no bypass valve, it sounds awesome and unleashes good power.
Get a dc sports header, 2.25 in exhaust downpipe and a 2.25 in cat converter (I use magnaflow) but then again, if you turbo, you better wait on the header and exhaust, they won't be good.
The exhaust muffler was the piece that was expensive and contributed least to power gains and it is the last piece I would have bought if I had to do it again.
If you are serious about your car, the auto tranny is the biggest deficiency in this model and needs to be reworked (torque converter with higher stall speed, etc. etc., clutches, plates, etc. see www.levelten.com)
If you're gonna spend ANY money, make sure you are willing to invest in the tranny, otherwise, modding this car will make it not worth all the money you're gonna put into it. sell it...
My next upgrades are digital ignition MSD 6AL, redoing my entire tranny with level 10, and finish off with a supercharger.
CONCLUSION:
The Integra automatic is one of those cars that requires a lot of thought before investing in it unfortunetaly. If I had the GSR, I would not think twice about upgrading it with an awesome turbo kit and all the mods you can think of. But you got to weigh your options on this integra automatic.
otterizer
92+ Civic/EL & Del Sol
03-31-2006 10:37 AM
vxn12
14
05-06-2004 07:59 AM
bonestock
05-05-2004 11:08 AM
b00gers
8
12-04-2002 08:10 PM
