11.1:1 Compression, what else do i need?
Old 06-27-2002 | 10:09 PM
insnimprtguy's Avatar
insnimprtguy
Honda's will never die!
what would b the best valvetrain set up?
i was lookin' at Toda Dual Valve Springs, Skunk2 Tit. retainers, JDM ITR intake valves, and Skunk2 exhaust valves, how's that sound?
Old 06-28-2002 | 04:09 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
JDM ITR pistons in a GSR motor will indeed yield around 11.4:1 without milling down the head. You said you're having the head shaved. That will easily bump your compression up a good bit.
Here's what I'd do, and it's a lot simpler/cheaper than all this nonsense you're proposing:
  • Go ahead with this port/polish--but skip out on milling the head beyond what's needed to make a smooth surface.
  • USDM B16 pistons (which can be had cheap from any Honda dealer)
  • ITR outer valvesprings (pay a visit to the Acura dealer), Portflow inner valvesprings, Portflow titanium retainers
  • skunk2 stage 2 cams
  • adjustable cam gears
  • some sort of chipped ECU that raises the redline and preferably doesn't disable the knock sensor
As fars as "what you need" to get to 11:1, it's not much. If you want to tear apart the motor and make some more power that's entirely different.
Old 06-29-2002 | 02:16 PM
ChillOutWayne's Avatar
ChillOutWayne
im building up my GSR soon, im looking at stage 2 Skunk cams, skunk2 tit retainers, skunk2 springs (whole set) and port and polish, im gonna leave the valves and the bottom end alone, until i move onto pistons later....MrFatBooty, if i take my head to a machine shop for a port and polish and spring and retainer install, how much about u think that would run me, (not for parts, but for install and polish) anyone can answer but it seemed MrFatBooty was the closest to stating what i was planning to do, thanx in advance
Old 06-29-2002 | 10:45 PM
qtiger's Avatar
qtiger
Why?
#1: Skunk2 valves come in a complete set only.
#2: Skunk2 valves are much better than JDM ITR valves. (Hype R!) All the ITR valves are is a little lighter. Skunk2s are flatbottom nitrided stainless steel.
For springs and retainers it doesn't really matter all that much whose you get, as long as they are stiff enough (Any aftermarket spring should do unless you are revving to the moon). Most of them are probably all the same rebadged Eibach spring anyway.
Remember, just because it is JDM, doesn't mean it is good.
Old 06-30-2002 | 12:11 AM
insnimprtguy
i know, just lookin' for some info on any other means of supportin' a 11+ compression, w/out spendin' tons of $
rynxprs
CRX & Pre 92 Civic
09-08-2002 05:24 AM
Quick Reply: 11.1:1 Compression, what else do i need?
