overheating need help!
Well, the radiator cracked once form the pressure build-up and a cfew weeks later it blow the creack where i used the jb weld stuff. So instead of buying a oem i figured i should go with a bigger radiator. If it still has pressure build the only other thing i can think of is the block brace not letting the water circulate fast enough.
Pure water may cool your motor better, however you don't have the agents that prevent corrosion in the coolant tracts throughout your motor. I wouldn't rely on JB weld to fix your radiator, it's only helpful so much. You may still be leaking or soon be.
JB and duct tape only go so far...if you want to go aftermarket look at pwr or fluidyne radiators. Since you have the head off you might want to think about enlarging the coolant passage holes on the blockguard.
i have extrem pressure build-up also: Shaved head, headgasket, new rad., therm., waterpump, timing belt..... got all this done and this piece of shit (sorry had to go there) is still making my brand new top rad. hose bulge like my pants on a sat. night!!!! what the heck is going on here 96' teggy LS w.o vtech
