Maintanance light...
My light just came on and i am currently at 112000 miles. I was wondering if there was anything taht needed to be done at this service interval, i am up to date on my oil change, so anything else that i need to take care of?
Thanks.
Thanks.
You'll need to clarify if this was the Check Engine light or Maintanence Required Light. If the check engine light came on, you'll need to jump the ECU diagnostic plug to read the code. If it was the maintanence required light, all that tells you is it's time for your oil change, that is if you've abided by that light for your oil change cycles and not used your own cycle.
