GS-R Weight Reduction
Old 02-18-2003 | 03:22 PM
eclipse spanker's Avatar
eclipse spanker
Default GS-R Weight Reduction
I was cruising through some websites, and I stumbled upon some weight figures for the teg............the LS weighs 2529 lbs, the type r weighs 2639 lbs, and the GS-R weighs 2765 lbs !! After reading this horrendous figure for the GS-R, I decided that my first project for mine will be some weight reduction. The wheels that I have weigh a little less than 13 lbs each, so that is a good start. Next, I will literally remove everything that does not NEED to be on there, while trying to maintain a stock appearance .
I dont know if any of you guys have dabbled with weight reduction at all, but basically I wanted to know if you guys knew of any parts on the GS-R ( starting with the jack and spare tire) that are of considerable weight AND can be removed ?
Old 02-18-2003 | 03:46 PM
XSrcing's Avatar
XSrcing
rear wiper and motor assembly. and if you really want to get into it, take out your entire interior (carpet and dash included) and remove the sound deadening. that would take alot of work, but it is all i can think of.
Old 02-18-2003 | 04:19 PM
MountainGSR's Avatar
MountainGSR
Irisher than Thou
I think Flex-A-Lite makes a rear-window replacement, too. Might check in to that.
Old 02-19-2003 | 12:16 AM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
Your figures are inaccurate, concerning the vehicles weight.
The curb weight for the Integra's are as follows...
Manual Transmission (2001 Sport Coupes Only)
Type-R: 2595 lbs (1177 kg)
GS-R: 2672 lbs (1212 kg)
GS: 2639 lbs (1197 kg)
LS: 2643 lbs (1199 kg)
Automatic Transmission
GS: 2680 lbs (1216 kg)
LS: 2685 lbs (1218 kg)
Old 02-19-2003 | 01:19 AM
DB7 2.0's Avatar
DB7 2.0
Banned
spare tire
jack
board (the "floor" part of the trunk that covers the spare)
carpeting/floor mats
plastic panels
rear seat
rear seatbelts
sound deadening material
carbon fiber/fiberglass hood
lightweight wheels
lightweight exhaust system header/piping/muffler
air conditioning unit
power steering unit
cruise control unit
lexan rear hatch window (for the coupes)
GSR = sunroof..cant do much about it except close it h:
i did everything i can to my 4dr except the rear window and front carpeting...it ended up being pretty damn light....but wayyyyyy too noisy inside. everyone always told me to close my windows when i talk on the cell...even if the windows were already up h: oh well, my interior is back to stock
Old 02-19-2003 | 04:59 AM
eclipse spanker
lol...ok thanks guys
Old 02-19-2003 | 06:04 AM
eclipse spanker
so basically the way it looks is that there isn't much that you can just "take off"........
Old 02-19-2003 | 07:25 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
What's the point of making the car that much lighter? You're not going to be doing any serious motorsports, right? It's still a daily driver, might as well keep it reasonably civilized.
Old 02-19-2003 | 12:15 PM
eclipse spanker
yes, but the thing is that I've noticed that even a few pounds makes a difference. Before my 12.5 lb wheels, I had some chrome wheels, and man, you can feel the difference !! With the chrome, it was like my car was being held down by a friggin ball and chain....then with the lighter wheels, the car was just way more responsive during acceleration and braking. I know wheels are a little different, because there are many factors at play (rotational mass, etc.), but I just figure that its a good way to reduce your e.t. , even if it is only by one to 2 tenths of a second .
Old 02-19-2003 | 12:18 PM
eclipse spanker
By the way, do any of you guys know about how much the power steering and cruise control units weigh ? And doesn't the power steering also rob considerable power, or is the difference negligible ?
