Clutch Question
Old 02-05-2003 | 08:00 PM
jeems's Avatar
jeems
i be slow
Default Clutch Question
my clutch is starting to feel kinda stiff. what are some of the possibilities of the problem? its in a 95 and its stock. i filled the fluid tonight.
you know how newer civic clutches are pretty loose feeling and its not like a workout everytime you shift? my left calf muscle is huge!
Old 02-07-2003 | 03:11 AM
JimBlake's Avatar
JimBlake
As far as the spring pressure, different cars are different. But here's a few dumb guesses if yours is getting stiffer than it used to be...
You filled the fluid - when was the last time you changed it? You should flush it every 2 years so its fresh. Old fluid is corrosive because it has absorbed moisture from the air.
How are the pivot bushings & pins & clevises of the pedal itself? Maybe they're getting dried up & need some grease.
Check out the rubber hose at the slave cylinder. Is it kinked or damaged in any way? You'd expect it to leak if its messed up, but maybe its collapsing inside? (I don't really know how likely this is, I'm just guessing.)
