valve cover gasket
Old 06-20-2002 | 11:38 AM
gsr44's Avatar
gsr44
Default valve cover gasket
hey guys...i plan on doing a valve adjustment this weekend and i will also be replacing my valve cover gasket. my friend changed his valve cover not too long ago, but he used a generic brand gasket sealant instead of honda bond. the instructions for the sealant said that it would take about 24 hours for it to cure, and he didnt drive his car till the next day. was that really necessary? is it the same w/ the honda bond or can i just drive it once i'm done?
Old 06-20-2002 | 04:34 PM
90'RS's Avatar
90'RS
I just had my oil seal at the end of the cam on my 90 replaced and they replaced the valve cover gasket with it and I drove it home once they where done and a guy that works at honda did it for me with no sealent at all.
Old 06-20-2002 | 04:42 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Best to follow the directions of the sealant you use and you should use some sort. I didn't use sealant once and it started leaking so I had to pull the valve cover again and get some sealant.
Old 06-20-2002 | 04:53 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Default Re: valve cover gasket
If you use a honda valve cover gasket no sealant required, just make sure you seat it properly, and check around the valve cover for leaking oil.
Project EVA - The Track Package
Project EVA
Old 06-20-2002 | 06:32 PM
gsr44's Avatar
gsr44
in the helms manual, it says to use liquid sealant on the designated points of the gasket. :dunno:
edit: you can also see the remains of sealant that was first used once you take off the valve cover.
stratguitarist
09-14-2006 04:16 PM
qualude
08-05-2004 11:26 AM
miaminikko
Engine Swaps, Tech & Tuning
4
06-25-2003 07:59 AM
T-RO
11-07-2002 01:57 PM
lewylou78
09-15-2002 03:52 AM
Quick Reply: valve cover gasket
