What to do...
Old 02-02-2003 | 06:53 PM
h0ckeyplr's Avatar
h0ckeyplr
Default What to do...
i currently have about 110000 miles on my 94 gsr.
I have allready had the timing belt replaced, along with the other things that were done at that servicing.
I was wondering if there was anything else that i should do now, or in the near future, for general maintainance on my car.
When should spark plugs be done, and when you do them should you replace the rotor?
Old 02-02-2003 | 09:18 PM
b00gers's Avatar
b00gers
sometimes i wish my scanner works....this is NOT all of the recommended maintenance....im not typing all the "inspects"...
7,500:
change oil
fill reservoirs
rotate tires
lube locks / hinges
15,000:
(7,500)
replace air filter
tighten f/r suspension mounting bolts
adjust valves
lube exhaust hangers
replace ventilation system charcoal
clean battery cables
change tranny fluids
30,000:
all of the above
change brake fluids
replace fuel filter, sealing washers
replace distributor cap /rotor
spark plugs
set timing
check pvc system
test and service battery
hope that covered most.
Old 02-03-2003 | 04:43 AM
h0ckeyplr's Avatar
h0ckeyplr
so i am supposed to do that at 107500 miles 115000 miles and 130000 miles, where did you look that information up?
Old 02-03-2003 | 06:07 AM
b00gers's Avatar
b00gers
those are 3 sheets that i got from acura. those are some of the "recomended maintainence" that they do.
if only i had a scanner to give more details on it.
