Building For Juice
Old 02-02-2003 | 03:15 PM
Orange95GSR's Avatar
Orange95GSR
Default Building For Juice
Ok so far Ive done most of the basics. Now I am really interested in building my internals for nitrous. I want to know what is the best Combo for me to use. I want my car to be a street/stip car that can do at least low 13s. What Rod/Piston setup should I use? Im really new to internals and I want to do it right the first time.
Thanks guys
Old 02-02-2003 | 07:55 PM
dubcac's Avatar
dubcac
I
You should be able to pull low 13's on a 75 shot with drag radials. Or you could just get a new clutch/flywheel setup, and then you'd be there. If not, you can run 100 shot on the stock block if it's properly tuned, and you have proper fuel and ignition components. If you want to build the motor, I would resleeve the block, get forged rods of your choice, forged pistons (stock compression of 10:1), balance/micropolish the crankshaft, stainless steel valves. MSD 6a ignition, Jacobs Nitrous Mastermind (progressive nitrous controller that also controls timing and minor fuel adjustments), inline fuel pump, and get it dyno tuned.
Old 02-03-2003 | 06:20 AM
Orange95GSR
Thanks Dub u da man.
