Timing Belt
Old 01-31-2003 | 09:30 PM
jeems's Avatar
jeems
i be slow
Default Timing Belt
When is the best time to get your timing belt changed?
Old 02-01-2003 | 05:38 AM
90'RS's Avatar
90'RS
every 60k but I suggest doing a few other thing while that is being done. Do a search because this has been discussed many times
Old 02-01-2003 | 08:56 PM
jeems's Avatar
jeems
i be slow
why not just tell me?
Old 02-01-2003 | 09:17 PM
stumpyf4's Avatar
stumpyf4
Best time is before it breaks!!
But seriously my 1998 helms recommends 105k miles, I think Honda upped their old suggested 60k miles. I would still suggest 60k miles if you drive somewhat aggressive. At the same time replace the waterpump, change the coolant (it needs to be drained anyways), replace all the all other drive belts (these need to be taken off anyways), adjust the valve clearance(valvecover needs to come off anyways), and inspect the cam seal (replace if there is a slight hint of oils seepage).
Pro-tip: Buy yourself a helms manual and do-it-yourself!!
Old 02-01-2003 | 09:54 PM
jeems's Avatar
jeems
i be slow
good lookin out yo
Old 02-02-2003 | 09:40 AM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
Most Honda engines are "interference" types, so if the timming belt breaks, kiss your motor adios. Pistons and valves crash into each other.
Old 02-02-2003 | 09:43 AM
reno96teg's Avatar
actually, it's every 90k.
Old 02-02-2003 | 04:31 PM
travis200's Avatar
travis200
It's 90k had mine done twice so far. Make sure whoever does it (if not Acura) they use original Hona parts. No cheap imitations here!
Old 02-02-2003 | 04:38 PM
kfar09's Avatar
kfar09
yeah i always heard 90K
Old 02-02-2003 | 06:13 PM
fastball's Avatar
fastball
A little chin music
Originally posted by jeems
good lookin out yo
Hi. Check your private messages. I sent you something off topic.
