Multiple Questions.
Old 06-23-2009 | 10:30 PM
Jetyee's Avatar
Jetyee
Actually i currently have a
Comptech CAI and Comptech Headers.
And Kind of a beginner to all this....
What is OBDI? and can you tell me what is in a 'tune'?
Old 06-24-2009 | 10:50 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
All cars after 1996 went to a system called 'On Board Diagnostics 2", meaning OBDII. To tune an OBDII vehicle, you need an EMS. They can get expensive, and they are very sub-par when compared to other companies like Hondata, eCtune, and Neptune etc.
A tune is when you have your ECU chipped, and have a tuner change and modify the stock maps. they go an add/take out fuel and spark, change timing, and so on. After I was tuned, my car felt like a whole different car, and it got better mileage. I averaged a few weeks ago 34.7mpg on the highway, which is freaking astounding when the GSR was rated for 22mpg city and 25mpg highway.
Old 06-24-2009 | 11:23 PM
Spec R's Avatar
Spec R
Originally Posted by pslsnakes
I would hold off on the final drive just yet.. If you're going to boost, you're probably want the slightly lower gearing to combat wheel spin, since the ITR tranny is already very short geared. The reason you see more boosted GSR's is because the GSR cost considerably less than a B18C5, and it's not worth it to spend thousands of dollars more for 25 more horse power when you're boosting it any way.
A GSR doesn't 'take it better', they're both completely the same. the only difference between a GSR and ITR is the tranny, the head is a factory ported B16 head, slightly more aggressive cams and a better valve train.
Oh, and post pics of your caR
the main difference being that the higher compression on the ITR isnt as FI friendly. h:
DB Squad
Integra Forum Moderator
Old 06-25-2009 | 12:51 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
You know what I'll say lol...
that little amount of compression isn't going to make it that much different in a F/I setup. If it was like 11.5:1+ it would be a different story. It's all in the tune.
Old 06-25-2009 | 01:50 PM
Jetyee's Avatar
Jetyee
-pslsnakes
i also have heard of there being different kind of tunes?
or is there only a basic tune for your car? and about how much would this tune cost?
Old 06-26-2009 | 06:11 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
What do you mean? A tuner chips your ECU, puts the chip in his emulator, and fine tunes all that maps and tables. Do you mean a street and dyno tune? A street tune is done to make sure the car runs good on anything lower than full throttle, make sure it idles smoothly, basically makes sure it performs just as stock or even better. On the dyno, he make adjustments to fuel and timing for wide open throttle performance. I had both done.
Where in California are you located? The price of a tune is going to depend on the program used, and more-so on the tuner's discretion
Old 06-29-2009 | 07:10 PM
Jetyee's Avatar
Jetyee
I live around the Bay Area in California. Near Pleasant Hill / Walnut Creek / Concord. So there isn't an average overall pay? its mostly dependent upon the tuner and what they use?
Old 06-30-2009 | 01:42 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
It really depends on the tuner and what program is used.
It's going to be hard to pass Cali emissions if the car is tuned, though.
Old 07-02-2009 | 09:27 AM
Jetyee's Avatar
Jetyee
I was thinking of possibly staying NA...
and going with cams and FD to start off.. how much wtq / whp could i roughly get with a budget?
can you give me like a chart like...
WHP / WTQ = ~$$$
WHP / WTQ = ~+$$$
Old 07-05-2009 | 10:45 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
There is no set dollar or power amount.. It's hard to say.. What fuel, how good the tune is, what parts you have, your designated powerband location...
I can also tell you you're not going to pass emissions with any mild to wild cam.
