the job everybody loves...changing a timing belt
Old 01-26-2003 | 12:22 AM
jeff's Avatar
jeff
Default the job everybody loves
when changing the timing belt on a 94 teg. non v-tec( b18b1 ) do I need to remove the engine mount near the timing cover? and if so, i should obviously use a jack to support it from underneath right? is there anything I should watch out for?
Old 01-26-2003 | 09:55 AM
g2tegls's Avatar
g2tegls
MR, ftw
If g3s are like g2s then you need to remove the mount. I didn't support the engine when I did it but who knows. I would if you're concerned about it. Hope this helps.
Ben
Old 01-26-2003 | 08:07 PM
stumpyf4's Avatar
stumpyf4
Don't need to support the engine, there are many other supports holding it in place. I'm going to change my own in the spring as well, along with the water pump and do the valve lash adjustment. May opt for a stronger belt, Toda or Power Industries since I'm saving some money by doing it myself.
