tps sensor
Old 05-20-2009 | 05:22 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Does the car even start and run? I remember messing with a buddy by unplugging the TPS and the car died instantly and wouldn't start until we plugged it back in.
Old 05-22-2009 | 12:58 PM
VPUPPY's Avatar
VPUPPY
The car will run without a TPS. You can replace just the TPS for under $50. Google or eBay "Omni Power TPS." You can make slots in the scews that are on the original TB and use a screwdriver to remove the old one. The new one, from Omni Power, will come with replacement screws. You just need to calibrate it. You can find out the steps by googling as well.
As an alternative, you can find another Honda TPS from a junkyard TB as well if that is easier.
Old 06-14-2009 | 06:12 PM
Eddog85's Avatar
Eddog85
cool thank but what do you mean by make slots in the screw how do you do that
Old 06-14-2009 | 09:31 PM
A-series's Avatar
A-series
v-card member alpha
^Use a dremel or similar tool to cut a slot in it.
Old 06-20-2009 | 09:00 AM
cruzalekz's Avatar
cruzalekz
you can drive with it unplugged.
your car will run in LIMP MODE also called back up mode, FMEM just enough to get you home or bring your car to a shop and not in a tow truck.
basically, the pcm uses another sensor to get info from. in your case, if the tps is out, the pcm uses the map sensors input. its not gonna be accurate thats why your car runs like S+it.
cel will come on off course
