No power anything now
Old 03-31-2009 | 09:28 AM
lostape's Avatar
lostape
Casual Participant
Default No power anything now
I replaced the worn out hinges on the driver side door of my 98 integra on sunday. the door lines up nice now. after I finished I noticed that the p/w and locks dont work on either door. i didnt mess with the passenger side at all. It doesnt make any sense to me. All of the fuses are fine. im about to pull my hair out. I would be happy to at least get the window up before it rains today
Old 03-31-2009 | 06:33 PM
Lynxs1981's Avatar
Lynxs1981
Are all your plugs connected inside the door? If these are undone, the other side won't work either. If these are in, then it sounds like the main plug going into the car from the door. I know you said you checked fuses but I just want to recap. Fuses under the dash are (94-97)#6 20Amp, #14 20Amp, and #36 under the hood. 1998+ under dash are #24, #11, #10(7&8 if 4 door), #1, and #46 under the hood.
Old 04-01-2009 | 03:42 PM
lostape's Avatar
lostape
Casual Participant
Alright, heres a picture of the plug from the door jamb. Looks like a couple of wires came out. how do i get them back in there in the right spot with all that goo in the way?
File Type: jpg
Old 04-01-2009 | 04:55 PM
Lynxs1981's Avatar
Lynxs1981
That looks to be your problem. That should just be grease to keep water out. Just wipe off what you can and then spray it off with brake cleaner or something similar.
Old 04-01-2009 | 06:28 PM
lostape's Avatar
lostape
Casual Participant
how do i know which wire goes where?
Old 04-02-2009 | 07:43 AM
Lynxs1981's Avatar
Lynxs1981
If you can see the wires on the other side, you should just be able to match them up. You might have to lengthen the wires and put regular spade connectors on them, it might be easier.
Old 04-02-2009 | 11:20 AM
Spec R's Avatar
Spec R
good job finding the problem guys
on another note, that grease looks...gross.
DB Squad
Integra Forum Moderator
Old 04-03-2009 | 05:57 AM
lostape's Avatar
lostape
Casual Participant
thanks lynxs, everything is workin now.
Old 04-03-2009 | 08:24 AM
Lynxs1981's Avatar
Lynxs1981
You're welcome. Good to know it's all working.
