what kind of trasmission fluid?
Old 06-17-2002 | 05:32 PM
kento's Avatar
kento
Default what kind of trasmission fluid?
what kind of transmission fluid should i be putting in my manual 95 teg LS? ... the manual i have says 10-30 or 10-40 engine oil? is this right?
Old 06-17-2002 | 05:53 PM
dubcac's Avatar
dubcac
I
Honda MTF :thumbup:
Old 06-17-2002 | 06:25 PM
StyleTEG's Avatar
StyleTEG
Make me an offer
I switched from Honda MTF to Redline, and loved it. Shifts much smoother, and I used to have trouble getting into second sometimes.. not anymore. :thumbup:
Old 06-17-2002 | 06:37 PM
reno96teg's Avatar
i'm using 10w30 and MIGHT go to honda MTF next change...
but 10w30 does me just right. :thumbup:
Old 06-17-2002 | 07:19 PM
AcuraFiend's Avatar
AcuraFiend
when you say redline are you referring to redline mtl? i was always told that **** was way to heavy to feed your tranny.
Old 06-18-2002 | 04:50 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
Yes, Redline MTL. You were told wrong.
a 70W80 GL-4 gear oil (SAE 5W30/10W30 engine oil viscosity) designed for use in manual transmissions and transaxles. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
Until honda made its own MTL, they recommended you use 10W30 motor oil in the tranny. Redline is fine.
Old 06-18-2002 | 08:35 AM
stumpyf4's Avatar
stumpyf4
Had Honda MTL in and switched to Mobil 1 10W30, no difference. Think I'm gonna try 10W40 or the Redline. My tranny is kinda notchy my buddies LS is supa smooth, he's using Syntec 10W30.
Marty.
Old 06-18-2002 | 09:54 AM
StyleTEG's Avatar
StyleTEG
Make me an offer
I wouldn't use a normal motor oil if you have the option, the newer Acura manuals specify to only use motor oil as a temporary sollution until you are able to obtain MTF.
Old 06-18-2002 | 07:17 PM
dubcac's Avatar
dubcac
I
You want the thinnest oil you can put in the tranny. Redline MTF is much thicker than the Honda MTF.
Old 06-18-2002 | 07:24 PM
zAd -'s Avatar
zAd -
redline performs better then the honda mtf everything gets way smoother
quote by knowlegable guy michael delaney from team-integra.net
most uninformed people believe that 30 weight oil is good enough for your tranny. In the gen 2 tegs, if you look at the owner's manual, Honda recommends this.
In the gen 3 tegs, the owner's manual recommends Honda MTF and not 30 weight oil...hydro trannies need a little more protection.
The Redline 80 weight synthetic GL4 is a step up in protection from Honda MTF.
You probably talked to an old timer who is a little behind the times and has not kept up to date....it happens...not his fault..he was giving you the best info he knows.
Quick Reply: what kind of trasmission fluid?
