Buzzing noise when i start the car
Old 01-28-2003 | 09:28 AM
MTXINTEGRA's Avatar
MTXINTEGRA
If it is stock, then it could be the catalitic converter heat shield. Mine does it and i've talked to some other people with the same problem. Talk about annoying
Old 01-29-2003 | 08:29 AM
JimBlake's Avatar
JimBlake
ABS or exhaust? What's this thread about? ABS really sounds like an electric pump, I wouldn't describe it as a rattle.
If you open the hood & have somebody listen while you start up the car, its pretty easy to tell where the noise is coming from. The location is very misleading for you sitting in the driver seat.
If its the exhaust, there's another possibility. My "A" pipe (from manifold to catalyst) made a rattling noise that sounded just like a loose heat shield. That piece is really a pipe-in-a-pipe, & the inner one was buzzing against the outer one.
That pipe cost so much that I used it as an excuse to get a DC header.
Old 01-30-2003 | 03:16 AM
JimBlake's Avatar
JimBlake
Default ABS leaking down?
Originally posted by MTXINTEGRA
Great!! time to fork out some more money for my car. Mine pumps every time I start my car.
I looked it up...
If it takes more than 40 seconds to pump up when you start the car the ABS controller stores a fault code & lights up the idiot light.
It also stores a code & turns on the light if it has to pump itself back up for no reason while you're driving.
Either way, all you gotta worry about is that the lamp is supposed to be on for a couple seconds while you start. The ABS is checking itself out, & you are paying attention (right?) in case the bulb is burned out. If the lamp doesn't stay on then its OK.
If the noise is actually your exhaust... never mind.
Old 01-30-2003 | 07:30 AM
Mintegra97's Avatar
Mintegra97
My car only makes the ratteling noise when its getting warmed up, god its most annoying. and I have the comptech catback.
Old 01-30-2003 | 10:04 AM
MTXINTEGRA's Avatar
MTXINTEGRA
Thanks jim for looking that up, i feel a little better bout it. My car only does it for a few seconds at a time.
Old 01-30-2003 | 06:45 PM
ITRraceR's Avatar
ITRraceR
My teg makes this whistling noise but thats from the alternator belt, it always does than when the car is cold, and it's not an abs because i don't have one lol
Old 02-01-2003 | 07:06 AM
Chrgsr96's Avatar
Chrgsr96
Default Whistling noise
Is there any way of getting rid of that HORRIBLE whistling noise. I get it soooooo bad all the time. It will happen for about 3 months and then just suddenly one day it will go away for a few months. And now it is back. It is sooo loud in my car, is there any way of fixing that?
Old 02-01-2003 | 09:27 AM
ITRraceR's Avatar
ITRraceR
you can try adjasting the tension of it, or get a special belt drssing spray and just spry all over it, that works for me most of the time, it only does that when it's really cold, like you said onece in a while and than it just goes away
Old 02-02-2003 | 10:51 PM
ULTiMaX99's Avatar
ULTiMaX99
hey i have this problem too. before the noise would come on then my ABS light would go on. i filled the ABS resorvoir up and it fixed the problem for a while but now sometimes the light comes on while im driving. I noticed that my resorvoir has gone down and its sorta wet in that area of the engine compartment. I think i have a leak in my ABS system somewhere...
Old 02-03-2003 | 07:34 AM
JimBlake's Avatar
JimBlake
Default Re: Whistling noise
Try some belt dressing, but I don't think that's a real good permanent fix. If it works immediately then you know you need a new belt. How old are the belts? If they're new, then probably the tension is wrong.
If the belt dressing doesn't work, then I'd be looking for a bearing that's starting to go. Use a foot of garden hose up to your ear to narrow down the location of the noise.
