beep beep beep......
hi guys i'm totally sick of my '96 Integra beeping at me for everything. BEEP! The door is open, BEEP! The keys are still in it! BEEP! You are reversing BEEP! BEEP!
My mate has a Land Rover Discovery and he found a trick of locking and unlocking several times to disable these alarms. I was wondering if anyone knows of a similar trick?
Cheers.
Cheers.
everything sounds like stock until u mentioned the reverse...either way, there is not a specific solution to turning off all the beeps from the factory aside from "tricking" the individual switches that turn on the beeping devices in the first place
DB Squad
Integra Forum Moderator
DB Squad
On my '90 Prelude Si it was super easy, just undid the cover over the rear-view mirror mount (mounted to ceiling, not windshield), unplugged the unit that made the sounds as well as lit up the seatbelt reminders, and it was fixed.
If you can find the location of the sound-maker unit(s), you could just remove it. Otherwise, on some cars you can remove the interior light fuse and it also disables the reminder noises - what I've done on my 5th gen civic in the past - otherwise there might be another fuse that will accomplish it.
