i think i figured out whats wrong with my code 22
Old 12-25-2002 | 11:50 AM
crash's Avatar
crash
Default i think i figured out whats wrong with my code 22
i think my oil pressure is low,and the vtec pressure switch is sensing that and making the ecu throw the code 22.
what do i do though to make the oil pressure right?
95 gsr
Old 12-25-2002 | 11:55 AM
reno96teg's Avatar
did you check your oil level? is it ok?
Old 12-25-2002 | 12:01 PM
crash's Avatar
crash
ya,but i just realized that's probaly not the problem,because if the oil pressure was dropping then the pins would probaly come out of the smaller rocker arms,thus deactivating vtec,and when the check engine light comes on vtec still stays engaged.i don't think i'll ever figure out whats wrong with my car.
Old 12-25-2002 | 03:27 PM
LT's Avatar
LT
The deer had to die!
why not just replace the vtec solenoid? could be the circuitry is going faulty.
Old 12-25-2002 | 03:52 PM
crash's Avatar
crash
i have replaced the soleniod,pressure switch,checked oil,checked voltage,checked grounds,and more stuff that i can't remeber.
Old 12-25-2002 | 04:00 PM
jclau00's Avatar
jclau00
i heard something about that if you use the rsx or new generation civic oil filters, that will boost your oil pressure. :dunno:
Old 12-25-2002 | 04:31 PM
crash's Avatar
crash
huh,hmm,uuh,oh?
Old 12-27-2002 | 01:26 PM
notnigel's Avatar
notnigel
new oil pump
Old 12-27-2002 | 09:59 PM
crash's Avatar
crash
i might be wrong though,cause if the oil pressure was dropping wouldn't the pins come out of the middle rocker arms and disactivate vtec?
how much would it cost to replace my oil pump?labor and parts?
Old 12-27-2002 | 10:04 PM
crash's Avatar
crash
ok oil pump is 122,but does any one know how long it would take to replace it,and roughly what someone would charge to replace it(labor only)?
