Integra speaker question?
Old 12-15-2002 | 06:42 PM
t3t4's Avatar
t3t4
Default Integra speaker question?
does anyone know what size speakers are in a 94 gsr from front to back?
Old 12-15-2002 | 07:06 PM
97teg's Avatar
97teg
crutchfield.com has the sizes. If doesn't have the tweeter seperate in the top of the door im pretty sure its 6 /12 in the front. Not sure about the back. Prob 5 1/4 or 6 1/2.
Old 12-15-2002 | 07:51 PM
XSrcing's Avatar
XSrcing
5 1/4 up front; 6 1/2 in back.
Old 12-15-2002 | 08:42 PM
b00gers's Avatar
b00gers
6x9 in the rears if you have a sedan.
Old 12-15-2002 | 08:47 PM
ISP James's Avatar
ISP James
DAMIMRED
i used 6.5's in both front and back for both my g2 LS and my g3 GS-R... just have to cut the back off of the plastic sheit that the speaker screws into... no big deal
Old 12-15-2002 | 09:24 PM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
If you cut the plastic off the original speaker mounting piece, make sure to buy some foam baffles for your new speakers, cause if you don't, water gets down between you window and door and messes up the speaker from the back.
Old 12-15-2002 | 09:43 PM
reddog's Avatar
reddog
It depends on the speaker in front. Everywhere says that in front it is 6.5, but when i went to install my alpine type-r component 6.5s, it was a total b***h. You have to cut the plastic thing and make a custom spacer, unless you want to cut at your door. So make sure you do your homework on the EXACT dimensions of the front speaker you would like to use.
As for the rear its a 6.5 on the coupe and a 6x9 i believe on the sedan, there should be plenty of room to make any speaker of the right size to fit with only minor modifications.
Old 12-15-2002 | 09:49 PM
crash's Avatar
crash
i have a 95 2door gsr, and just finished installeing 6.5 inch in front and back.
both fit perfectly how the stock speakers fit.
Old 12-16-2002 | 06:50 AM
BonzoAPD's Avatar
BonzoAPD
what are some good speakers to put in a G3 teg coupe?
Old 12-16-2002 | 07:00 AM
XSrcing's Avatar
XSrcing
what brand and model speakers did you put in?
