98 Gsr??
Old 08-19-2008 | 06:05 PM
gingas's Avatar
gingas
Default 98 Gsr??
How's everyone doing? Fine I hope. This my question. I still have my oem exhaust. Where the cat. converter is but,6 inches back the heat shield is split & rattling like crazy. Can I get away with not using that shield w/ out any heating issues.
Thanks
Old 08-19-2008 | 10:18 PM
Spec R's Avatar
Spec R
Thanks
technically you can, but you might feel extra heat around your armrest/shifter area.
DB Squad
Integra Forum Moderator
Old 08-19-2008 | 10:38 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Mine was like that when I bought the car. I took it off and never looked back.
Old 08-20-2008 | 08:30 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Other than a little extra heat under the armrest you should be fine with removing the shield all together.
Old 08-20-2008 | 10:06 AM
reno96teg's Avatar
i was concerned about that myself, so i first secured it with hose clamps. i eventually gave up after it would eventually start rattling again and removed the heatshield altogether.
like joe said, there's a little extra heat under the armrest, otherwise it has been no issue.
Old 08-20-2008 | 01:22 PM
gingas's Avatar
gingas
Glad to know. It'll be like that for a while until I can get the money for a cat back exhaust.
Old 08-21-2008 | 06:11 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Just don't use a metal shift knob either or you'll be fucked when it comes to shifting.
Old 08-21-2008 | 07:01 PM
gingas's Avatar
gingas
I have the titanium ITR knob. It's not hot unless in the sun several hrs. It's garaged. Yeah, the rattling is annoying
Old 08-23-2008 | 05:52 PM
2001TEGGSR's Avatar
2001TEGGSR
Keep in mind that a cat back exhaust system won't offer any solution to the problem, unless you are buying a high flow or new cat at the same time.
You might try sourcing a replacement heat sheild from junkyard, or online somewhere if the heat bothers you.
Old 08-23-2008 | 06:07 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Jesus guys the heat isn't going to be this dramatic! Trust me, you'll barely notice any difference if you don't pay attention.
