Changing transmission fluid
Old 11-17-2002, 02:22 PM
lucgirl79
lucgirl79's Avatar
Does it make a difference if I drain or not? I only want the best for the life of my car
Old 11-17-2002, 04:00 PM
LT
The deer had to die!
LT's Avatar
hmm...get Honda ATF and then redrain and put in Redline!!! however, i do believe Redline doesn't make ATF fluids...i'll go check.
Old 11-17-2002, 04:02 PM
LT
LT's Avatar
yes they do make ATF fluids...
http://www.redlineoil.com/products.htm
Old 11-17-2002, 04:05 PM
antarius
Large Member
antarius's Avatar
Bah. I disagree with LT6916.
Not to say Redline doesnt make a great product, I prefer putting in what the Honda Engineers designed the car for, which is ATF.
I'd drain the oil. Put in 2.9 quarts of Honda ATF and run the car for 10-15 min. Then come back in, drain it again and refill it with 2.9 more quarts of Honda ATF.
Old 11-17-2002, 05:40 PM
lucgirl79
lucgirl79's Avatar
Honda ATF and Redline ATF... what are the differences in these two brands?
Old 11-17-2002, 05:53 PM
antarius
Large Member
antarius's Avatar
Supposedly Redline has improved on the stock ATF fluid -- but Honda tested and designed their tranny's with the Honda ATF so I'd go for that.
I think Redline is more synthetic or something so it "lasts longer"
Old 11-17-2002, 05:55 PM
LT
LT's Avatar
its synthetic meaning...its thinner and has LESS viscosity than OEM ATF...however being thinner, it MAY have less coating on the gears. However, this is Redline we're talking about...they design things better than Honda.
Old 12-01-2002, 05:45 AM
TTZ
TTZ's Avatar
Take it down to the Lube Center and pay for a transmission flush. Your transmission will drive like new. Seriously, you will be impressed with the improved shifting.
Old 12-01-2002, 05:19 PM
stumpyf4
stumpyf4's Avatar
Good call TTZ... the lube boys will replace all the fluid in the transmission including whats in the torque converter that you normally can't drain. 100% replacement of fluid.
What the other guys are recommending a double drain and fill is for the same reason, can't drain the torque converter but try to displace as much old fluid as possible.
The lube boys can do a better job with their equipment.
Old 12-01-2002, 07:34 PM
sutrusu
turbo > bodykit
sutrusu's Avatar
i'm running redline MTL in mine and it's dandy. shifts are smoother. a lot of people say no to synthetic, but mine is holding up fine.
