do the 1997 integra ls brake rotors need to be pressed on???
:werd: If you end up stripping the heads of the screws just drill the heads right off, I never reuse those things. It only takes a whole 30 seconds of drilling and the heads are gone.
Maybe you haven't come across ones that have been on there for a while (mine was 7 years). It had a slight rust on there, too. I first used a philips head screwdriver, but they would not budge. I tried to twist, hammer the driver + twist, PB Blaster then hammer + twist, but none worked. $10 impact driver solved that problem.
....or a drill and bits you already have
i broke my impact driver bits on my car yesterday.
no way in hell NOT using an impact driver (regular screwdriver) would have gotten them out.
i eventualy had to drill the heads out.
once i did that, the rotors were pretty stuck on the hub. it took a good number of whacks with a BFH to knock em loose.
yes, i tried using a bolt in the threaded holes to pop em off, but that didnt work either.
fun times.
fun times.
DB Squad
Integra Forum Moderator
DB Squad
