Cold winter warming?
Old 11-06-2002 | 04:59 PM
MountainGSR's Avatar
MountainGSR
Irisher than Thou
When I lived in the Rockies (negative overnight/morning temps) I warmed my cars up for 5-10 minutes everyday. Partly because it can be tough to reach operating temps when it's extremely cold outside, and secondly because I like my car warm when I go out Anyway, I think that if you live in a very cold area let her warm up to operating temp while sitting there. If you live somewhere where it's not as bad (Tucson, AZ, for instance ) I say just keep it under 3k-4k until you get to op. temp.
Old 11-06-2002 | 06:04 PM
antarius's Avatar
antarius
Large Member
It's always good to warm up your car until at least the automatic choke is off (the idle is normal) which is almost always normal operating temperature.
That's kind of impossible though, I mean, do we all get up 20 minutes early to start our car so it can idle for 10 minutes? No.
I just turn mine on, go back in and brush my teeth/comb my hair and come back out and get in the car and drive. That's all.
I'm in California, it's rarely ever below 45F when I get in the car. and its garaged.
Old 11-06-2002 | 06:13 PM
str8edgexx's Avatar
str8edgexx
a general rule that I have always followed with any of my cars is that when the temp gauge raises up to where the "C" is (as opposed to sitting down below it), then I'll go. If the car is totally cold, that takes about 5 minutes.
Old 11-06-2002 | 07:35 PM
XSrcing's Avatar
XSrcing
in gs-r's, everything functions normally once the temp guage is above the "C" line. so i just waited till it got there.
Old 11-07-2002 | 03:13 AM
newgsrdriver's Avatar
newgsrdriver
It isnt good to let it idle for a long time, or until its fully warmed up.
You should only idle it a bit, then just drive very conservatively to allow all the moving parts to get lubed properly and remember what their job is
Old 11-07-2002 | 05:55 AM
reno96teg's Avatar
Originally posted by newgsrdriver
A lot of people think different things...
I prefer to sit in the car and let it idle for a minute or two. Then just keep the revs under 3k until its warmed up a bit. Theres a bunch of different theories on this...I tend to think this is a good medium and makes the most sense.
this is exactly what i do.
Old 11-07-2002 | 05:56 AM
JackoliciousLeg's Avatar
JackoliciousLeg
root
Are you guys/gals sure that VTEC doesn't engage on the B18Cs until the car is warmed up? I know that the new RSXs won't go past 5k, because there's a cold temp revlimiter. I've never tried to rev mine into vtec when the car was cold and probly won't, but can someone let me know if it's true?
JackO
Old 11-07-2002 | 10:15 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
JackO
I am almost 100% sure, for the oil circulation reasons I stated above. Note that this was info I read from somewhere else, not my own personal knowledge of the b18c or anything.
One time in HS I was in a hurry, so I cold-started my car and hit 8000 rpm pulling out from my parking spot. Didn't hear the secondaries kick in at all, and I felt ultra slow (not to mention ultra stupid as my car made a lot of noise and didn't go anywhere). I highly doubt the vtec cams would be able to kick in if your temp was pegged at C.
Shingo
Old 11-07-2002 | 11:35 AM
antarius's Avatar
antarius
Large Member
Yes, 100% sure.
It wont engage until it's warm because there's not enough oil pressure to make it engage.
Old 11-07-2002 | 12:20 PM
bucash's Avatar
bucash
So you can redline a GSR without VTEC kickin in? That does make sense. I have herd of people not having enough oil pressure when trying to redline and the rpms just dont go that high.
