Koni Yellows?
Old 11-02-2002 | 05:37 AM
integraty's Avatar
integraty
Default Koni Yellows?
I have got eibach pro kit, and was going to use some Koni Yellows for shocks, but, they said that the Koni Yellows are "ride-height adjustable?" I am just double checking that i can actually lower or raise the ride height of my car? Or can you just adjust the stiffness of the ride? Let me know what you think.....
Old 11-02-2002 | 06:15 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Koni yellows have 3 perches so you can adjust to some degree the stance of your car. They are rebound adjustable only, which does play a role in your ride quality.
Shingo
Old 11-02-2002 | 06:42 AM
porschetr's Avatar
porschetr
You can't adjust it once it's on the car.
Old 11-02-2002 | 07:04 AM
integraty's Avatar
integraty
how much of a degree? half an inch or so? and do they ride like you wanted them to?
Old 11-02-2002 | 08:51 AM
antarius's Avatar
antarius
Large Member
Something like that. I never measured how much the perch allowed me to adjust the car, since I have Groudn Controls anyway.
You cant adjust the perch once its on your car, but you can obviously adjust the stiffness of the shock itself.
Yes, they're wonderful.
Old 11-02-2002 | 09:22 AM
integraty's Avatar
integraty
so if i wanted to drop the front about half an inch or so, could I with the KONI's and is there any other shocks that are ride height adjustable?
Old 11-03-2002 | 05:43 AM
Tony96EX's Avatar
Tony96EX
There's about 1/2" adjustability between highest and lowest perch settings. I think for tegs, the default perch setting is the middle, so the max drop is 1/4".
