99 Integra driver side door lock sticking
Old 03-30-2008 | 08:35 PM
adhuot01's Avatar
adhuot01
Default 99 Integra driver side door lock sticking
The driver side door lock sticks when I push the lock/unlock switch on the door, I hear clicking inside the door but it usually only moves the lock tab halfway. Ther seems to be some restriction. Is the acuator bad or should I remove the trim panel and and check for obstructions.
Old 03-31-2008 | 12:09 AM
9of9's Avatar
9of9
gl with your problem seems like people on here dont know shit about cars...i for one had the same problem you have now and a buddy of mine told me to replace the acuator...and problem solved...youre better off goin to honda-tech or teamintegra for future question..people on there actually are helpful
Old 03-31-2008 | 06:40 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Don't listen to that moron.
Usually it's the actuator but before you go replacing parts, pull off the door panel and apply lube to the appropriate areas with a light application of lithium grease. This might loosen things up and usually this helps with the problem but if it persists then i'd replace the actuator.
Old 03-31-2008 | 01:22 PM
adhuot01's Avatar
adhuot01
Default 99 Integra dr. sd. door sticking
Thank you, I thought the same thing, I have some teflon water-proof lube I might try to apply to that area
