Nitrous questions??
Old 10-24-2002 | 05:18 PM
dubcac's Avatar
dubcac
I
Nitrous doesn't blow motors, stupid people running it blow motors. I don't know anyone who's blown a motor on nitrous, but then again we know how to tune.
Stock GSR, 125 shot NOS plate kit...2 years, a bottle a week...still perfect compression.
Stock LS, 75 shot Zex, one year, numerous bottles.
Stock Lude, 75 shot Zex, two years, numerous bottles.
Stock LS, 125 shot Direct Port, one year, numerous bottles.
If you're blowing motors on a 50 shot, you're doing something SERIOUSLY wrong.
As for the mechanic, they don't know jack about nitrous or building motors. They know how to fix. They'll also tell you that putting on a lightened flywheel will blow your motor too
Old 10-24-2002 | 08:41 PM
hks240sx's Avatar
hks240sx
NNNNNNNNNNNNNNNNAAAAAAAAAAAAAAAAAAAAAAWWWWWWWWWWWW WWWWWWWWZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Old 10-24-2002 | 09:51 PM
dubcac's Avatar
dubcac
I
You are officially a homo. Please refrain from posting in any thred in a tech forum on this board. Thank you.
Old 10-24-2002 | 10:09 PM
JEFFOS69's Avatar
JEFFOS69
Ive been running a NOS dry kit for a year now with no problems.
Old 09-14-2003 | 12:46 AM
aznxguy12's Avatar
aznxguy12
Originally posted by antarius
For a beginner kit..
.Go with a ZEX Nitrous Kit. You can't go really wrong. 50-60 shot just get a step colder plugs and you'll be 100% fine.
If you go to a 75, you may need to adjust your timing a tad, but not much (ask dubster for exact info).
I recommend the ZEX because it checks your fuel pressure and adjusts flow accordingly, so you dont lean out; it also ties into your ECU so its easy as hell to install on your own.
NOT TRUE, I have a del sol, ran a 15.6 on a d16 motor, ran last wed. after i passed the traps my powersteering went then the motor died, found out one fuel line from the Zex unit flew off, n how come the Nitrous computer didn't compensate n turn off the nitrous? i dunno. so now i have a melt plug that came from cylinder# 3 and no compression coming out of it, thinking it could be one of two things...pistion rings or melted or bent valves, in the process of taking the head part to check it.
Old 09-14-2003 | 01:22 AM
NIXONride's Avatar
NIXONride
surfer
why use "homo"... please refrain from posting that
Old 09-14-2003 | 10:55 AM
dubcac's Avatar
dubcac
I
Damn..back from the dead.
Maybe try clamping down the fuel lines and you won't have this problem. The Zex kit does not have a nitrous cut feature, it simply adjusts the fuel pressure according to the pressure of the nitrous. But when that fuel line comes off, it's instantaneous that you're not getting fuel anymore...no nitrous cut feature is going to be that fast.
How's retard? Better?
Old 09-14-2003 | 05:42 PM
aznxguy12's Avatar
aznxguy12
[QUOTE]Originally posted by dubster99
[B]Damn..back from the dead.
I did clamp it after that was only line i didn't have clamped down. can't be too safe...take the longer route, just took apart the head today finally, got to cracked exhaust vavles. probably just gonna change them all.
Old 09-14-2003 | 07:12 PM
dubcac's Avatar
dubcac
I
Damn, that sucks man...just build it bigger and better, and spray more :rick:
Good luck :thumbup:
Old 09-14-2003 | 07:58 PM
ShaolinLueb's Avatar
ShaolinLueb
N.O.S. is good but ZEX is better if you tune the engine right you can handle 50/60 shots and not worry abouty tearing apart your engine
