Map Sensor Q
Old 11-06-2007 | 07:50 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Default Map Sensor Q
So for my turbo install (if I ever get around to it) I've read about upgrading the stock MAP sensor so when under boost my car won't throw CELs.
I found Motorola 2.5 bar map sensors on EGay for $25. Says they are for Honda/Acura D16, B18, B20 and H22. Obviously requires soldering, nothing I can't handle. My question is should I get one? I'm not sure what psi I'll be running, I'm shooting for 230-240whp with my setup and I'm thinking to get this sensor if I end up running more than 10psi...
Old 11-06-2007 | 01:42 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The stock MAP sensor will read up to 11.2 psi. There is no need to upgrade unless you plan on running more boost than that.
