Poor gas mileage on my new purchase
Old 10-24-2007 | 11:38 PM
95LSv's Avatar
95LSv
Banded
Well I used the Honda top end cleaner today, changed fuel filter and got a aem filter on my aem sri (used to have some cheap bs filter before)... Now I just have to drive it and see if anything improves. I'm going to do cap and rotor, spark plus, wires, pcv, timing belt (just because its at 105,000 miles and never had it done) and water pump.
Old 10-25-2007 | 11:30 AM
Difussion3's Avatar
Difussion3
Touge
yea you should definetly do your timing belt right about now.
Old 10-27-2007 | 12:20 PM
95LSv's Avatar
95LSv
Banded
Well, its still wasting a lot of gas. I just checked the injectors and cosmetically they look perfect (no cracks, buildup...). I also changed the oil, oil filter, and sprak plugs yesterday.
Old 11-01-2007 | 10:13 AM
Zooty's Avatar
Zooty
Jimmy John's Driver
Yeah, I just bought a 96 LS, and I too have noticed the gas mileage being kind of bad (im used to my 93 civic si )
I got it two weeks ago, and the guy put new plugs,distributor, and a whole tune up, and everytime he had an oil change he just got a whole tune up so it theoretically should be fine.. Maybe its my filter or something?
I'd try to drive let erratic but my first gear feels kind of weird, like i have to get over a little hump in the road before it goes or ill stall.. maybe my civic clutch was just too light?
Edit: I forgot to point out i'm borderline 200k miles, and since it's an LS, no vtec
Old 11-01-2007 | 10:17 AM
Difussion3's Avatar
Difussion3
Touge
I've been trying not to drive hard. On my last tank, I filled it up to 3/4 full, and I got 235 miles. Is that good? I just filled up yesterday to the max, so now I'm going to see how much I really get to a full tank.
Old 11-01-2007 | 10:42 AM
Zooty's Avatar
Zooty
Jimmy John's Driver
I dunno how BIG of a diff it makes but i noticed with my civic if you always only fill it to half thats less water weight on the car, so technically you should get a TINY bit more MPG, at least it seemed like it did..
Old 11-02-2007 | 09:26 AM
cruzalekz's Avatar
cruzalekz
its could be something as a lazy o2 sensor. but i would do a compression test both wet and dry and a leak down test to test the mechanical part of the engine. You already did the basics i understand and should have cleaned up all the crap that you have in the valves. Also consider valve adjustment. O hey, any problems with the idle PRM?
Old 11-03-2007 | 12:10 AM
95LSv's Avatar
95LSv
Banded
dry compression was at 180 +- one or two all accross. But it doesn't matter anymore, the car is totaled. Thanx for the help guys.
Totaled car thread
https://www.honda-acura.net/forums/s...d.php?t=280559
Old 11-03-2007 | 06:29 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Originally Posted by Provocateur
You would probably get better gas mileage winding it out to at least 4k. h:
No need to make a torqueless wonder work so hard.
You know what, I retract my previous stmt. I shift around 4500, not sure why I said 3. Brain fart...
Old 11-03-2007 | 06:32 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Is that city, city and highway or just highway?
