2nd gen top speed
Old 09-02-2007 | 03:00 AM
bighroder's Avatar
bighroder
Default 2nd gen top speed
I wanted to know what you guys with 2nd gen integras top'd out at. assuming you did this at the track. i am looking more towards cars with five speeds and 1.8 non vtecs
thanks
Old 09-02-2007 | 07:28 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
There are so many different "top speeds." Stock 2nd gens would probably get up to 120-130, but people say they go faster and I think thats bullshit. The highest speed you could probably get out of the stock gear ratios at red-line in 5th gear would probably be around 145-155ish. You'll never see those numbers because you would be aerodynamically limited to less if you don't have serious power.
Old 09-02-2007 | 09:39 AM
pissdoffB's Avatar
pissdoffB
Little Miss Dee
I have a LS motor (1.8 non v-tec) hooked up to a b16 tranny and I run out of gear at 135.
Old 09-02-2007 | 10:17 AM
bighroder's Avatar
bighroder
is there anyway to switch the gear set? i am just learning about import cars i was big into hot rods and v8's. Does one of these 5 speeds even have a ring and pinion?
Old 09-02-2007 | 01:53 PM
Snoopy's Avatar
Snoopy
been there done that
b series tranny's are easily swapped between b series engines. b16/itr tranny's are the shortest geared of them all.
honda's are fwd and dont have rear ends (with one exception) so they dont have a ring and pinion
Old 09-02-2007 | 03:30 PM
bighroder's Avatar
bighroder
so if i want higher top speed i would want the tranny that is in it right? ir do i have it backwards?
Old 09-02-2007 | 03:52 PM
Snoopy's Avatar
Snoopy
nonvtec b series tranny's are the longest geared and theoretically will give you higher top speeds, but unless you're doing high speed runs on salt flats, is pretty pointless to have.
Old 10-30-2007 | 04:44 AM
lando77's Avatar
lando77
Default Hello From Germany
Hi, I unfortunately have an 01 GSR and 07 TL Type S, so this information does not truly apply, however, I do know how fast a TL or Integra can go.
If I run My GSR up to Redline in fourth, before shifting to fifth I can usually get it up to about 140mph (on a slight decline and in the morning)
MyType S has a 160 mph Speedo, so all I can say is that it is faster than 160mph.
Lando
Old 10-31-2007 | 09:01 AM
bnuk's Avatar
bnuk
this is probably heading towards a lock but when you are talking about top speeds its almost always an issue of power vs. drag not gearing. A GSR won't run out gears until 160+ but it has nowhere near enough power for that. A lot of cars will even hit a higher speed using one gear from the highest, I would imagine that is true for a stock LS.
Old 10-31-2007 | 10:06 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
As long as there is no mention of doing this on the street and remains constructive, there isn't a problem with it.
