Will I be happy with this turbo GSR?
1999 gsr with 58k miles
Full-Race stage 3 turbo kit T3/T4 T67 turbo with an .82 ar housing four bolt, 3 inch down pipe (if your not fimiliar with Full-Race please visit their website at Full-Race.com so you may see the workmanship and quality of the parts they sell)
Tial 38mm wastegate 10 psi spring
Tial 50mm blow off valve located on Full-Race's patent back door intercooler
PWR radiator
Quaife differential
Head has springs, retainers, titanium valves, valve guides from Ferera and a three angle valve job with port and polish as well
AEM stand alone computer
AEM wide band in cluster
Ground Control springs with Koni yellow 4 way adjustable shocks
Full 3inch Thermal exhaust to sound nice and calm not your typical annoying Honda/Acura running the streets
Traction control bars
Catch can setup to relieve pressure from being turbo through the crank casing
ACT three puck clutch unsprung
Fidanza flywheel 7lbs
880cc injectors wired to a resistor box so the car can idle like stock
PWR radiator
Quaife differential
Welcome.
Personally, I wouldn't purchase someone else's project but in this case, it could be an exception. All the parts look to be very high quality and no corners look to be cut.
Have you driven the car yet? With a turbo that large, I imagine the lag would be pretty noticable. Any idea on what kind of power it is making and at how much boost?
No not yet, I am driving it tomorrow. I am a little concerned that the block is not built, but at only 10 psi and proper AEM tuning I should be ok. 880cc injectors..there goes the 4cyl fuel economy lol.
I thought it was actually making some decent power instead of being oversized for the application. The insane amount of lag that setup should have would turn me off completely.
What do you think it is worth? White w/ black leather 60k miles. I don't mind doing somework like building a block and then swapping it in or buying a smaller turbo and retuning if the lag is too much (until the block is built ). What I don't want to be is upside down in the car too much when the time comes to sell it.
He doesn't have one. I am getting the car in trade on one of my cars that he wanted. It is white withe black leather full factory body kit that I guess was a $4k option new when ordered? It has only 59k on it and comes with a spare block that has been sleaved. It looks like they are going for anywhere from $8k to 13k on the trader and there is a lot of money invested which you never fully get back. All of the GSR's that are comprable to year and condition and mods I have seen seem to be going for $13-17k. Is that way far off or close to realistic?
