Gas Pedal Shakes at 7500-8200 rpm
JRSC GSR
Ever since I installed my JRSC, my gas pedal has been shaking almost violently at times at 7500-8200 rpm in every single gear.
It did this when i ran the JRSC at stock timing with no boost going for a while, and then it still did this at the exact same rpm range when i retarded the timing and added the SC belt in order to run boost.
Anyone ever ran into this problem of their gas pedal shaking.
I'm thinking its gotta be something to do with my throttle body, or the throttle body cable, but when I looked over it, I had no leaks from coolant lines, the cable was properly tightened, and everything looked fine.
any ideas?
any ideas?
