Bushings for a 95 integra
Old 07-08-2007 | 11:59 AM
x6against7's Avatar
x6against7
Default Bushings for a 95 integra
I just purchased performance bushings for my '95 Integra and was wondering if anyone knew of a how to guide for doing them.
Old 07-08-2007 | 12:58 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Which bushings? Rear trailing arm? Toe control link?
In a general sense, you remove whichever linkage the bushings are in, use a press (or a torch) to push (or burn) the old bushing out. Then clean the inside face of the bushing mount, lube up the new bushing and press it in.
Old 07-09-2007 | 04:12 AM
bnuk's Avatar
bnuk
Thats pretty much it. Team-integra.net has a lot of how-to articles. they may not have it for the specific bushings you have but they should have something explaining how to remove the suspension components you are wroking on. I would suggest just removing the control arms or whatever you are working on and droping them off at your local shop. They should press the old ones out for $30 or so. well worth it if you ask me. The rubber is some pretty amazing stuff and doesn't burn out very easily at all.
Old 07-09-2007 | 07:01 AM
pnthr30's Avatar
pnthr30
I just did this on my car (all suspension pieces).........pay to have them pressed out (or go buy a press). They do not burn easily and are NOT easy to get out without a press. Can it be done, yes, but IMHO it is money well spent to have it done quickly. I am assuming you got poly bushings? If so, they are easy to put in. Worst part is getting the sticky lube all over your hands.
