obd0 to obd1
Old 07-07-2007 | 03:29 PM
hachacker5024's Avatar
hachacker5024
Default obd0 to obd1
hey i am converting to obd1 from obd0 and want to just cut the old harness and splice in the obd1 connectors for the ecu the only thing is i cannot find a pin out diagram or anything, if anyone knows of one that would be helpful.
also i have a sensor that is from the obd0 harness and on the 0bd1 motor there is no spot for it, but the connector is still there, i do not know what kind of sensor it is it is located on the back of the block right near the oil filter i think that it is the knock sensor from the obd0 motor which is that plug and sensor that have no where to go on the motor,
Old 07-07-2007 | 04:30 PM
ccb18c's Avatar
ccb18c
Weetec
Hope this helps
If you want to convert your obd0 Honda (generally pre-92) to obd1 standard,
follow the diagram/pinout.
Obd0 to Obd1 wiring harness conversion pinouts:
53 to 45 pins. + 4
A - 18
B - 11
| pin_id | wire_color | pin_function | pin_name | 4G OBD0 (PR3 pin)
| A1 | BRN | INJ1 | INJ1 | -> A1
| A2 | YEL | INJ4 | INJ4 | -> A7
| A3 | RED | INJ2 | INJ2 | -> A3
| A4 | GRN/YEL | VTS | VTEC solenoid | -> ADD -> vtec selenoid
| A5 | BLU | INJ3 | INJ3 | -> A5
| A6 | ORN/BLK | PO2SHTC | O2 sensor (heating element) | -> ADD [o2 heater control ->blk (under wht wire)]
| A7 | GRN/BLU | FLR1 | fuel pump (main relay) | -> A12
| A9 | BLK/BLU | IACV | IAC valve | -> A11
| A12 | GRN | FANC | engine coolant temp switch | -> B4
| A13 | GRN/ORN | MIL | MIL (check engine light) | -> B6
| A15 | BLK/RED | ACC | (a/c compressor clutch) | -> B3
| A16 | WHT/GRN | ALT C | alternator | -> B5
| A20 | RED | PCS | EVAP purge control solenoid | -> A6
| A21 | YEL/GRN | ICM | ICM | -> B15
| A23 | BLK | PG1 | ground *(main relay ground) | -> A2
| A24 | BLK | PG2 | ground *(main relay ground) | -> A4
| A25 | YEL/BLK | IGP2 | to main relay and to gound for o | -> A13 [splice for o2 -> blk (under grn)]
| A26 | BRN/BLK | LG1 | gound | -> A18
| B1 | YEL/BLK | IGP2 | to pin A25 | -> A15
| B2 | BRN/BLK | LG2 | ground to shields for CYP & TDC | -> A16
| B5 | BLU/RED | ACS | a/c switch | -> B8
| B9 | BLU/WHT | | starter signal | -> B13
| B10 | ORN | VSS | vehicle speed sensor | -> B16
| B11 | ORN | CYP P | CYP -P | -> B10
| B12 | WHT | CYP M | CYP -M | -> B12
| B13 | ORN/BLU | TDC P | TDC -P | -> C3
| B14 | WHT/BLU | TDC M | TDC -M | -> C4
| B15 | BLU/GRN | CKP P | CKP -P | -> C1
| B16 | BLU/YEL | CKP M | CKP -M | -> C2
| D1 | WHT/BLU | VBU | Back Up Power | -> B1
| D2 | GRN/WHT | BKSW | brake switch | -> C10
| D3 | | KS | Knock Sensor | -> ADD -> Knock sensor
| D4 | BRN/WHT | SCS | service check connector | -> mil [toggle switch with ground]
| D6 | BLU/BLK | VTM | VTEC pressure switch | -> ADD -> vtec pressure switch
| D9 | WHT/RED | ALT F | alternator | -> B14
| D10 | GRN/RED | ELD | electric load detector | -> B19
| D11 | RED/BLK | TPS | TPS Signal | -> C7
| D13 | RED/WHT | ECT | ECT sensor | -> C6
| D14 | WHT/RED | PHO2S | O2 sensor | -> C16 [splice for o2 -> wht]
| D15 | RED/YEL | IAT | IAT sensor | -> C5
| D17 | WHT/YEL | MAP | Map Signal | -> C11
| D19 | YEL/WHT | VCC1 | MAP 5V | -> C15
| D20 | YEL/BLU | VCC2 | TPS 5V | -> C13
| D21 | GRN/WHT | SG1 | MAP GND | -> C14
| D22 | GRN/BLU | SG2 | TPS GND | -> C12 [splice for o2 -> grn]
