oil pressure guage connected to the vtec oil pressure sensor
was owndering if i could connect a oil pressure guage/solenoid to the vtec oil pressure sensor. i cant be bothered to get behind the engine and do the typical setup.. could this be done at the vtec pressure sensor.. oh by the way its a GSR motor.
has anyone done this, please advise..
It can be done. Just make sure the VTEC sensor is straight off the T from the head to be sure it's gets the best flow.
I ran one from the port in the front of the head, but that's just to monitor my VTEC pressure.
could show me a pic of what it look like and all the measurements of hardware used.
Here's a few pics. All the fittings can be purchased at your local Home Depot, Lowe's, etc... Except the adapter fitting that goes into the head. That has to be purchased from AutoMeter.
http://i62.photobucket.com/albums/h9...Mar15_0002.jpghttp://i62.photobucket.com/albums/h9...Mar15_0001.jpg
Also, my setup only reads pressure when VTEC is engaged.
2 questions..
1. why does it only give you a reading and the point of vtec?
2. whats your readings at at vtec point
thanks again in advance
