F'n cooling problems won't stop!!!!!
Old 02-28-2007 | 08:22 AM
2001TEGGSR's Avatar
2001TEGGSR
The fan relay should be located in the engine compartment fuse box. I'm not positive as my experience with the older generation Integra is limited.
As for the oil and coolant crossing paths, I was just throwing that out there incase it was overlooked.
Good luck!
Old 02-28-2007 | 04:15 PM
92GTA's Avatar
92GTA
Thanks, I'll go through that fuse box again and track it down.
Sorry if the coolant comment came off wrong, I appreciate the help.
Thanks!
Old 03-12-2007 | 06:26 PM
Lynxs1981's Avatar
Lynxs1981
Sounds like you might just have air in the system. If it up in the head passages, it can be a bitch to get out. If your cooling system is working correctly, you shouldn't really be seeing much movement looking into the radiator anyways. Does your reservior stay full?
