Attn header owners:
Old 02-09-2007 | 07:19 AM
Topend's Avatar
Topend
scooted
Ive looked around for the torque specs for an exhaust manifold on a b18c1 motor. Im talkin about the 7 header to head bolts and the 2 outside nuts. the torque specs for the outside 2 nuts is 23ft-lb. For the header to head bolts is said to be 22ft-lb. when I got here they all felt somewhat loose. Whats a "realistic spec" to follow. I know 23 on the header to head bolts was not enough to I went to 30. any thoughts? its fine with no leaks. should i leave it or back it up. I also had an extension on the wrench. does this matter?
there DC's case that makes a difference
Old 02-09-2007 | 12:37 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:wavey: Got your PM; I'm reposting the answer for the general public here as well.
Originally Posted by TheOtherDave™
Originally Posted by Topend
hey theotherdave, got a question thats seriously bugging me. Ive posted a thread on it but was reading around you sound like a reputable person to ask.
I installed my dc 4-1 header. When it came time to torque the 7 bolts and 2 nut on the flange to head part, the manuals Chilton and haynes only gave me torque specs to the outside 2 nuts. it said 23 so i put them around there. the 7 others though didn't have specs so i tightened them to a realistic spec judging off the tightness of the other nuts. I came up with 30ft-lb that looked and felt right (not to tight) do you remember what you tightend the 7 header to head bolts to? thanks
First, dump your chiltons manual in the nearest trashbin and order the factory service manual from HELMS. From my experience, the Haynes / Chiltons manuals are absolute crap.
And from the Helms manual, the correct torque spec is 23 lb ft for all the nuts. Work in a criss-cross pattern (top-to-bottom) from the middle pair of nuts outward. The locking nuts at the ends are the very last ones to go on.
Since you've overtorqued the inner nuts, there's a possibiliy that you've crimped the header gasket. If that's the case, go ahead and replace it. Better to spend a few extra bucks rather than have a nasty (and noisy) leak develop a couple hundred miles later.
:cheers:
Old 02-09-2007 | 12:52 PM
jesusublime99's Avatar
jesusublime99
At least download the manual until you can buy it, easy to search for whatever you need:
http://www.hondahookup.com/manuals/
Old 02-09-2007 | 01:08 PM
TheOtherDave™
Apathy Kills
Permit me to give a brief speech... h:
Nut up, do the right thing and buy the FSM. :nono:
Personally, I take issue with the downloading of these manuals because:
1) It's a niche market already.
2) There are relatively few players who offer reprints to the public.
The FSM is worth what they charge and I don't want to see their prices go up because more people steal.
Thanks for listening...er... reading. :run:
Old 02-09-2007 | 03:06 PM
jesusublime99
I never perceived it that way, point taken. :wtcslap:
Old 02-09-2007 | 03:57 PM
TheOtherDave™
Apathy Kills
No need to chastise yourself. :hsd:
I was just tossing in my 2˘. h:
Trying to stop the flood of illicit downloading is like trying to bail out the ocean with a teaspoon.
