brake issue
Old 02-02-2007 | 02:55 PM
fgfournet's Avatar
fgfournet
R ENVY
Default brake issue
I had a problem wiht my brakes. When driving i have alot of noise (scraping). I checked the brake disc and found that they are warped. All four are in the same condition. The first time i had this problem I had the rotors spun and replaced the pads. 2 months later it happened again. My question is what caused this and will changing the discs and pads save me from having to do this again?
Old 02-02-2007 | 04:10 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
You may have a forzen caliper and/or frozen slide pins. I would check every caliper piston and make sure they compress all the way in(front) and turn all the way in(rear). Then I would check the slide pins and make sure those aren't seized into the caliper mounting bracket. Were your pads worn abnormally(slanted surface, one is more worn than the other)?
Old 02-02-2007 | 05:26 PM
dubcac's Avatar
dubcac
I
Having the rotors resurfaced won't really get rid of the warping problem. If it was only happening to one rotor, I would look at a frozen caliper problem. Since it happened to all of them, replace the rotors and pads...should be good to go.
Old 02-02-2007 | 11:43 PM
fgfournet's Avatar
fgfournet
R ENVY
I did some visual inspections not much wear on the pads. They may have about 3-4k on them, so still fairly new. I did check the reservoir and the fluid was getting low will a leaking caliper cause any of the above problems?
Old 02-05-2007 | 08:50 AM
bnuk's Avatar
bnuk
yeah check that all the pins are free to move. for a quick check after a some good city driving touch your calipers and see if if both fronts are about about the same temp and do the same for the rear. If one is noticicably hottter it is probably hung up to some degree.
Old 02-05-2007 | 04:52 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
:werd: Also a softer than normal pedal is a sign of a stuck caliper or slide pin.
Old 02-05-2007 | 05:48 PM
fgfournet's Avatar
fgfournet
R ENVY
I'm going to check this my pedal is noticable softer than my wife's Integra. Thanks for the info and help
Old 02-07-2007 | 08:50 AM
bnuk's Avatar
bnuk
How so?
I know with drum brakes if the little racheting adjuster gets stuck it can make your brakes soft (more distance to move pad before it contacts the drum) how does this happen with disc brakes?
Old 02-07-2007 | 09:27 AM
fjm1's Avatar
fjm1
G35
do you brake with left or right foot?
Old 02-08-2007 | 02:54 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
How so?
Because if you have a stuck caliper slider, the caliper piston would have to move out more than it has to and cause the pedal to have a softer feel and it would feel like you need more pedal travel to get brakes.
When I'm at work and i have a car with a softer than normal pedal, thats the first thing I go to after I look at the reservior.
