View Poll Results: Iridium spark plugs are they bad or good?
"Against!" Iridium spark plugs use what the manuel says to.
46.67%
"For!" Iridium spark plugs they way better than platium.
53.33%
Voters: 15. You may not vote on this poll
Iridium Spark plugs ?for or against?
Old 01-28-2007, 03:01 PM
KarrNtegGSR
KarrNtegGSR's Avatar
Default Iridium Spark plugs ?for or against?
I like to see who has had good or bad experace Iridium spark plugs? Are the worth the money? What brand is the best? Or are you totally against Iridium Spark plugs and why?
Old 01-28-2007, 03:21 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
I've used them and I didn't like them. They are overpriced and if that little piece of iridium breaks off into the combustion chamber, it will be a messy affair. I prefer basic copper plugs.
Old 01-28-2007, 04:42 PM
dubcac
I
dubcac's Avatar
Copper owns.
Old 01-28-2007, 05:18 PM
2001TEGGSR
2001TEGGSR's Avatar
For normal operating conditions I recomend OEM spec Platinum or Copper plugs. Replace them more often instead of splurging for more expensive, over rated iridium versions.
Here is some info:
Simply put, in high performance N/A engines there is no need for iridium (temp.) and platinum does afford some benefits over copper in a stressed engine. In FI engines, iridium may offer some advantages but using platinum does not hurt performance. You can use platinum coated copper electrode plugs which give you the heat advantage of copper and the arc-voltage advantage of platinum...just to throw more confusion into the mix.
So, platinum provides a smaller sharper electrode to allow a larger arc-over-voltage and will burn off before allowing an engine to detonate. Yes it is more expensive but it lasts longer.
Basically the smaller the electrode (has less Capacitance for those into electrical stuff) then less voltage it needs to fire. The bigger the electrode the more current it can flow (good in cars with heaps of power available, huge sparks).
http://www.team-integra.net/sections...?ArticleID=419
Old 01-28-2007, 07:10 PM
Zedron
Turbo B20
Zedron's Avatar
NGK: BKR7E-11 or it might be BRK7E-11
I have a turbo sleeved b20-vtec running 17psi daily and plugs are gapped to 30. These are the hizzle.
Old 01-28-2007, 07:14 PM
Provocateur
On permanent hiatus
It is BKR7ES-11. I am running these too.
For a stock motor, the correct copper plug would be a BKR6ES-11.
Old 01-28-2007, 07:53 PM
Zedron
Turbo B20
Zedron's Avatar
:werd:
The 6 are for vtec and the 5 is non vtec according to the parts store.
Old 01-28-2007, 08:19 PM
Buyimports2
Buyimports2's Avatar
If you have an OEM engine, but the cheapest plugs you can find, it doesn't matter. We had an engineer from Champion Spark plugs give us a talk. He gets free plugs and still chooses the cheapest ones because has says anything else is probably a gimmick. Like those plugs with multiple leads on them. It can only spark to one at a time, so it really help at all.
Old 01-29-2007, 07:04 AM
GSRRacer95
Fight On!
GSRRacer95's Avatar
I use the OEM part number.
Old 01-29-2007, 08:44 AM
BKKloppenborg
Love my Acura
BKKloppenborg's Avatar
I have been using NGK Iridiums, i love them and so does my car. I have tried Denso Stadards, and also Platinum's. But so far my teg loves the NGK Iridiums the best, i HATED the Denso standards. I have never had a issue with NGK Iridiums yet.
