Blown Gasket
Old 01-21-2007 | 01:24 PM
Difussion3's Avatar
Difussion3
Touge
Default Blown Gasket
How do I know if I have a blown head gasket or valve cover gasket?? And how quickly should i replace it. It's a pretty slow leak. But I dont feel right having my car leaking and looking ugly.
Old 01-21-2007 | 10:06 PM
2001TEGGSR's Avatar
2001TEGGSR
What are the symptoms of the alleged bad gasket?
Old 01-21-2007 | 10:10 PM
Difussion3's Avatar
Difussion3
Touge
oil leak... part of the left side of my motor has oil all over it...
Old 01-21-2007 | 10:23 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Pictures would help.
I have a small leak between the head and block on mine that even a fresh head gasket and head resurfacing couldn't remedy. I have noticed most blocks have a mild leak around where the engine code is.
Old 01-21-2007 | 10:32 PM
2001TEGGSR's Avatar
2001TEGGSR
I've heard this before too. Apparently most B series have this problem. Luckily I haven't had this problem yet, since the rebuild.
Cam seal is also a possibility.
Old 01-22-2007 | 06:23 PM
Difussion3's Avatar
Difussion3
Touge
Yea its kinda around and towards the bottom of the distributtor... right around where it says B18C1. I'll take some pics to show yhou guys...
Old 01-23-2007 | 12:04 PM
MTEng's Avatar
MTEng
'left side" as you look at the engine from the front of the car or left side as you sit in the car driving it?? The distributor end is the RIGHT side of the engine
Change the valve cover gasket with the "kit" that includes plug tube seals, grommets, etc.... and change the O-ring on the distributor base... those leak a lot, too.
Put a small dab of Hondabond in the corners of the VCG when you install it.
Old 01-23-2007 | 12:16 PM
2001TEGGSR's Avatar
2001TEGGSR
I just use Driver or Passenger side to avoid confusion from the dyslexic.
Change the cam seal too. If it's still loosing oil, clean the engine off and you should get a better idea of where the leak is.
Old 02-03-2007 | 05:10 PM
Difussion3's Avatar
Difussion3
Touge
ok well here are some pics i said i was gonna post. What do you guys think? any more pics to break it down a lil more?
Old 02-04-2007 | 02:47 PM
Provocateur
On permanent hiatus
Mine leaks from there too. It isn't too big of a deal depending on the flow rate of the leak. If it is only a few drops every couple days, I wouldn't worry about it. When you replace the gasket, chances are you will have to have the deck and head resurfaced to prevent it from leaking in the future.
