Blown Gasket
Old 02-04-2007 | 02:55 PM
Snoopy's Avatar
Snoopy
been there done that
yup i have a leak there too. it's not too bad but does get annoying having to deal with.
Old 02-04-2007 | 11:04 PM
Difussion3's Avatar
Difussion3
Touge
so where exactly is the leak coming from?? Is it a blown head gasket or much worse than that?
Old 02-05-2007 | 06:58 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is coming from in between the block and head. It isn't a blown gasket, though. I have been trying to troubleshoot mine, so I replaced the headgasket, had the head resurfaced and it still leaks. The last thing I can think of to do is have the deck resurfaced.
Old 02-05-2007 | 03:57 PM
jesusublime99's Avatar
jesusublime99
I had this same exact leak when I bought my gsr. I replaced my head gasket because I had to, and the leak stopped after that, I suppose I got lucky.
Old 02-07-2007 | 12:28 AM
hondub's Avatar
hondub
^ -dub +da
Is it just me or does it look like its leaking from the vtec solenoid? I believe theres an seal there which you might want to check out. Maybe i'm looking to far into it but it looks like theres oil stains higher up than the headgasket. good luck
EDIT: Sorry not the vtec solenoid itself but in between it and the cam. Im not positive about vtec engines but I know my ls leaked form that plug like a sieve.
Old 02-07-2007 | 02:12 PM
2001TEGGSR's Avatar
2001TEGGSR
I agree, the Vtec Solenoid and Cam Plug are contributing to the problem. However, I doubt replacement would make a noticeable difference, as It's obvious that the head gasket is also leaking.
Old 02-07-2007 | 09:23 PM
Provocateur
On permanent hiatus
Good eye. It does look like the leak originated from the vtec solenoid gasket or the cam seal. Since it still looks like the stock cam seal, it would be a wise investment to purchase a Golden Eagle cam seal to prevent any further leaks.
Old 02-07-2007 | 11:02 PM
Difussion3's Avatar
Difussion3
Touge
hmmmm i guess i might as well do that. How much does one run for?
Old 02-07-2007 | 11:19 PM
jesusublime99
Less than $30 shipped for tha Cam seal.
http://www.accountwizard.com/clients...lass=Cam+Seals
Old 02-08-2007 | 08:22 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
My money is on the vtec solenoid and cam seal. I had the same leak about 4 months ago. Replaced both and now the leak is completely gone.
