Transmission/Clutch Issues after Clutch Job
I have a 96 Integra GSR and just changed my OEM exedy clutch/pressure plates/bearings out as the clutch had started slipping. I did not replace the fly as it was straight without gouging and just cleaned up the surface with scotchbright. Anyway, tested the clutch for engagement and drove my car off the lift and then went into first and nothing would happen. I could shift into gear but the clutch would act like it wasn't engaged. RPM register on the speed when engaging gears. I took it back into the building and rebleed the clutch and still nothing. I believe it is engaging the gears but nothing is happening. I also played with the clutch throwout arm and it seems like the clutch is engaged. Any thoughts?
Thanks
Ryan
Thanks
Ryan
On permanent hiatus
Have you tried adjusting the engagement height at the pedal?
When I replaced my clutch, I had to bring the engagement height up because it was engaging at the floor.
www.ufc.com
That sounds great, but not resurfacing that flywheel may cause you some problems down the line. It may have looked fine to the naked eye, but I am willing to bet there were still imperfections that need to be negotiated.
www.ufc.com
