Best Intake for Turbo
I have a sleeved B20 block w/ JE 9.0/1 pistons, and eagle rods. I am currently using a LS head but might change over to a B16 or GSR head later on in the future. What would be the best Intake manifold and aftermarket throttle body to get for both a LS head and Vtec head?
Thanks
Thanks
Yeha I know that. I wanted to know what ones are the best because i am using a stock LS IM on my LS head currently. Im not sure if I want to go Vtec so I would like to know for further reference. IE: compare prices, etc etc
it is made for both, but the same will not work for both...
http://sportcompactonly.com/performa...aspx?c=70&b=25
I second the Edelbrock Victor X. The huge plenum and short runners make it perfect for boost. A Edelbrock Performer X 65mm throttle body would be a good compliment.
Were you asking if the manifold fit both vtec and non-vtec heads? They aren't interchangeable. If you are thinking about doing an lsvtec, it would probably be wise to do it before you think about a manifold.
I know they are not interchangable. I havent decided to make my B20 vtec yet. If I decide not to go vtec then I will just get the IM for the LS head. Thanks
