ACL issues RODS & MAIN
Old 12-03-2006 | 06:43 AM
NwAmH's Avatar
NwAmH
hatch that gets snatch
Default ACL issues RODS & MAIN
Ok i have a complete set of ACL bearing, but they are all standard so as far as clearance issues can i use them even if my crank isnt all standard. I prefer the people who have used ACL for a few builds, because someone who going off of another persons experience. Is it preferred to mix and match acl with oem?
Old 12-03-2006 | 10:53 AM
Nors's Avatar
Nors
倍力恋
Yes I believe most people mix and match. Since ACL bearings maybe fine for some journals and too big/small or others. Jeff Evans has a great write up on this I believe.
Old 12-03-2006 | 11:51 AM
2001TEGGSR's Avatar
2001TEGGSR
Is your crank in OEM condition?
ACL Bearings are all the same thickness as "Green" Honda bearings. If your going to use them, Plasti-gauge your clearances! Be sure they fall within tolerance. I guess you could mix and match with OEM's to achieve the optimal Oil Clearance, but it defeats the purpose IMO.
Old 12-03-2006 | 01:10 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I rather use a Bore gauge or a micrometer, because plasti gauge can lie. ACL also makes Under and Over sized bearing also
Old 12-03-2006 | 03:11 PM
2001TEGGSR's Avatar
2001TEGGSR
Yes but the after-market over sizes come in larger increments than OEM. Over sized/Under Sized bearings are used when the crankshaft is ground & re-surfaced (which Honda does not recommend!). When you order ACL .010" over, your still getting a "green" sized bearing. They are just .010" thicker, and there is no available "step sizes" to adjust your oil clearance to honda's precise requirement.
A dial bore gauge is excellent to measure the bores, and a micrometer will measure the bearing thickness - but how can you be positive of your oil clearance? If funds allow, use them! I still recommend plasti-gauge to double check, however.
Old 12-03-2006 | 06:53 PM
NwAmH's Avatar
NwAmH
I had the crank sent to a remanufacture company (Napa) where they completely redone the whole crank (weld new journals) machined to factory spec. So, i guessing all greens all the way across. The rods are eagle rods.
Old 12-03-2006 | 07:31 PM
Snoopy's Avatar
Snoopy
been there done that
what happened to the crank that you needed to repair it? spun bearings?
Old 12-04-2006 | 05:01 PM
NwAmH's Avatar
NwAmH
yeh spun bearing....but they crank is fully re-manned and block has been inspected and it cleared just getting my bearing fitted
