Spark Plug Stuck
Old 11-27-2006 | 08:49 AM
elljayess's Avatar
elljayess
Default Spark Plug Stuck
95 Acura Integra, Special Edition, Automatic, 4 cyl.
Mechanic broke a spark plug and piece is stuck (car still starts and runs). What tool can I use to try to get it out?
Old 11-27-2006 | 09:47 AM
fjm1's Avatar
fjm1
G35
Is the "broken" plug firing? Running on three cylinders?
The reason I ask is that if the car is running normally, spark plugs are easier to remove from a warm engine.
Even if the ceramic/tip is busted all you should need is a socket and plenty of leverage. Try to get any fragments out of the hole with a shop vac before removing the brpken plug.
Old 11-27-2006 | 10:13 AM
elljayess's Avatar
elljayess
I think it's firing because the spark plug cap flies up and down. It's not actually running normally. It sounds like a sick truck and I can smell gas.
Old 11-27-2006 | 10:42 AM
FooD2000's Avatar
FooD2000
Still Water
yea, it's probably running on 3 cylinders. Sounds like a wrx? your getting lots of fuel / air but no spark so that one cyl is just flooding. What part of the spark plug broke?
If it's just the threads stuck in there then you may have to drill it out.
Old 11-27-2006 | 11:50 AM
fjm1's Avatar
fjm1
G35
Is the head rounded off or is there just the threaded portion left?
Old 11-27-2006 | 12:16 PM
elljayess's Avatar
elljayess
Dang. I really don't know if it needs drilling or not. I'll try the socket, but the mechanic who broke it said he tried and couldn't get it loose.
Exactly how dangerous is it for me to drive on it as it is?
Old 11-27-2006 | 01:19 PM
gsrclan's Avatar
gsrclan
I did a google search, "easy-out" was mentioned frequently. I don't have any personal experience though.
Old 11-27-2006 | 03:27 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Even the though the spark plug broke, the part you grab with the socket should still be available. Ok...so hit it with some PB plaster, let it soak for 5 minutes and it should come free. Righty tighty left loosey. Don't worry about the pb blaster it will burn off quick once you start sparking again. No big deal.
Old 11-27-2006 | 03:32 PM
car2ner316's Avatar
car2ner316
king of all large n small
wtf kinda mechanic leaves someone in a bullshit situation like that? if you cant get it out with the advice thats already been posted try dynamite.
Old 11-27-2006 | 05:11 PM
g290ls's Avatar
g290ls
they call me tater salad
lol no need to blow up the teg, you should be able to put some leverage in and she should come free
