oil leakage
Old 10-25-2006 | 10:18 AM
hmgemperor2003's Avatar
hmgemperor2003
Default oil leakage
i have a 94 gsr and i have a oil leak problem. i fixed the leakage from the valve cover but it is leaking from another spot, the block. i hear that it can be the cam seal. or is it from a different area? help me out please
Old 10-25-2006 | 10:50 AM
primetime's Avatar
primetime
could be from the head gasket or the vtec solenoid! your probably going to need to change everythin one by one until the leak is gone.
Old 10-25-2006 | 11:16 AM
2001TEGGSR's Avatar
2001TEGGSR
Look under & try to see if your oil pan gasket is leaking.
If not, it's a good idea to just replace Valve Seals (will cause blow-by), Vtec Solenoid, Cam Seals, etc.
How much oil are you adding? How many miles?
Old 10-26-2006 | 05:21 AM
fjm1's Avatar
fjm1
G35
Cam seal is a common spot for leakage. It's the round plug below the valve cover on the distributor side. A little Honda Bond (like silicone gasket in a tube) and your fixed.
Old 10-27-2006 | 03:23 PM
g290ls's Avatar
g290ls
they call me tater salad
could be the pan gasket
