1993 gs
Old 10-23-2006 | 02:49 PM
fearless559's Avatar
fearless559
Default 1993 gs
I was told from owner previous owner that one of my front springs was cracked . . their is like a rattiling noise coming from the front when i go over bumbs . the back end makes a really load noise suound like shocks and strut change will be next what should i expect to pay for replacing the two front springs and all the shocks/struts?
Old 10-23-2006 | 03:29 PM
fastback's Avatar
fastback
Springs don't crack. If it did, you would not have a spring right now, but there are things in there that can. Rattling noise could be a lot of things, so you need to clarify what kind of sound it makes or take it to a mechanic. Is it speed sensitive? Does it happen when you turn or even when you go straight? It could be ball joints, bad strut, damaged sway bar bushing mounts, bad radius rod bushings, damaged axles, etc...
