car starts then dies instantly
not alll the time but some times my car starts then dies instantly itll run for a second then die sometimes it will do it once, sometimes like 5 to 10 times in a row. then it will run perfect idk. but in the past the check engine light came on once in a while but rarely now i dont notice it anymore
thanks for the help in advance
The ECU has the check engine light stored, unless you have reset it. The check light code could be the key to fixing your problem.
Do you know how to jump the ECU? If so, try to see if you can pull a code. RSvtec I see!
You should edit the title of your thread if you're going to go off topic. The fact that your car starts then dies instantly has nothing to do with jack points. Also, you have a vtec head on an LS block and don't know where the jack points are; that makes me wonder.
http://www.team-integra.net/sections...p?ArticleID=34
http://www.team-integra.net/sections...?ArticleID=651
