moisture in headlight
my passenger headlght has moisture inside. Somehow there's a damn spider web in the other drivers projector. Is there an easy way to either clean the inside of the lens between the projector and the plastic or am i just screwed.
Haha yeah if you heat it too long it will melt the headlights.
heat it between 150-220 for about 2-3 minutes NO LONGER. it may be a little tough too come apart but it will eventually come...im sure your a big boy
Do you close the oven door during this 2-3 minutes or do u leave it open?
thats the only option there is? doesn't that smell horrible when you put them in the oven?
How do you reseal them. Cause this is really driving me nuts. I'm still baffled how the damn spider got inside the light and made a spider web
put in oven, usuing a flat head screw driver go all the way around and try to pry it open, keep on checking it so you don't melt the headlight. once you done, put the two piece together, put it back in the oven until the sealent get soft, press the two piece together with your hand; until they're somewhat seal then use a plier, go around the headlight and gently squeeze the two piece together. done this 3 times already,
