Help with PowerSlot Rotors!!!
Old 09-30-2002 | 05:55 PM
antarius's Avatar
antarius
Large Member
Originally posted by WiLL
is there enough fluid? when i pump my brakes when the car is off, it would budge about .25-.5"
when you stomp on the brakes, do you think itll have better stopping power if you were able to keep pushing past the floor?
The fluid is 100% full.
I slam on the brakes as hard as I can (they arent broken in mind you, so I only did it twice) but it seriously didnt even lock up the tires (and I dont have abs). It used to lock them up without even thinking, so I figured new brakes, calipers and pads it would be super easy to stop
But I hit the floor (or as far as the pedal can go) before it stops any harder.
Old 09-30-2002 | 06:16 PM
ForceFedGSR's Avatar
ForceFedGSR
You either have air in your brake lines and they need to be bled or your master cylinder is faulty and needs to be replaced. Nothing else to it, its one or the other.
Old 09-30-2002 | 06:23 PM
antarius's Avatar
antarius
Large Member
It didn't do it with my stock stuff 10 minutes before I brought it to them.
and they rebled the lines.
odd.
Old 09-30-2002 | 06:26 PM
ForceFedGSR
well.... they must do shotty work
Old 09-30-2002 | 06:39 PM
antarius's Avatar
antarius
Large Member
So you think it's a failing master cylinder or ****ty work in the lines....
What should I check for on the master cylinder, to see if it's leaking?
It's not losing any fluid.
Old 09-30-2002 | 06:51 PM
Taiwanze7's Avatar
Taiwanze7
sounds like they didn't bleed the brakes correctly, its possible that its your master cylinder but last I checked, they shouldn't need to touch it if you're just swapping brake pads and rotors
Old 09-30-2002 | 06:53 PM
ForceFedGSR
You cant see a master cylinder leak usually...they leak internally.
Old 09-30-2002 | 10:17 PM
airon's Avatar
airon
AARONNOJIMA.COM
there is also a method to bleed brake lines
not sure how much that would affect it but still may wanna try it
Old 10-01-2002 | 06:19 AM
reno96teg's Avatar
bleed your lines and see if this still happens. also, it wouldn't hurt to check the installation.
why didn't you just do the install yourself? it's super easy.
Old 10-01-2002 | 06:30 AM
antarius's Avatar
antarius
Large Member
They've been rebled...
Why? Because I didn't have to pay for it
